April 06, 2020, 09:23:51 AM *
Pages: [1] 2 3 4
Author Topic: MG GM Type C - Cannon Fodder GB  (Read 10685 times)
« on: March 13, 2011, 11:05:07 PM »
This is what I am building for the group build, will hit it with plaplate, might do some scribing and some koto parts and will weather it as well, so it wont be a clean mech at all
Its an enjoyable build that goes together fast, being an older kit has the dreaded seam lines but I guess anything that keeps you working on your basics is a good thing right?
dj898
Re: MG GM Type C - Cannon Fodder GB
« Reply #1 on: March 14, 2011, 09:07:45 AM »
these old kits are great way to enhance/polish the c-joint mod. as well as other usual mods to make it easier for me to paint and snap afterward Lego style~ ^ ^
ZETA NEWTYPE
  • GAF Returner
« Reply #2 on: March 14, 2011, 11:25:48 AM »
The GM Type C always looks damn good, and in your build, it's no different.
Shifty
« Reply #3 on: March 14, 2011, 02:18:06 PM »
Fixing seem line are one of the great parts of it all right ;)
shadow298
  • UNLEASH THE GUAN
    • And the Geek Shall Inherit the Earth blog
« Reply #4 on: March 14, 2011, 02:57:25 PM »
nicely done, sir! \m/
"Ego futurus. ut est totus"
-I Exist. That Is All
for geek related goodness, check out these: @andthegeekshall
http://andthegeekshallinherit.tumblr.com/
http://andthegeekshall.wordpress.com/
Ranalcus
  • Stole the precious thing
« Reply #5 on: March 14, 2011, 05:55:03 PM »
Looks good, but what is a "c-joint mod"?
« Reply #6 on: March 14, 2011, 11:32:34 PM »
Thanks guys got some ideas on how to mod this so with any luck will get a chance to do some work on it in the next couple of days.
Ranalcus, its where you have a joint that is a pin inside a circle, and you cut the circle so its like a C that way you can take the parts apart for easy painting.
nicksu
« Reply #7 on: March 15, 2011, 12:18:10 AM »
Thank you for explaining C term, I called V shaped cut.
This is going to another great work still remember the zaku2.0 you built in last GB on old forum.
Gunpla Builder
« Reply #8 on: March 17, 2011, 08:36:02 AM »
Started playing with this last night
Drilled out the existing guns and replaced with Wave parts
Has been puttied and sanded back
Added a couple mm to the neck, cut and inserted some sprue frame in there, this has been cleaned up since picture
Now looking at two options for the front skirts
1, building up plaplate under a koto option part so it sits like the rx78
2, go with plaplate instead, I'm leaning more towards this one
More to come maybe tonight
« Reply #9 on: March 17, 2011, 10:50:00 PM »
Plaplate for sure. Love the neck extension. Very clever! ;)
Oh how I miss having GAF 1.0 to link to... DJ had the most righteous C-Joint mod thread there.. :(
« Reply #10 on: March 18, 2011, 01:42:34 PM »
Cheers dude, did the same thing with the hands, gave them an extension of a couple mm so it can hols the weapon a bit better.
With the neck mod, lets him look down like he all cool and badass :)
Went with the plaplate on the skirts, double layer on the front, single on the back
Did some butcher work on the arms, have done one, still have to do the other
Plaplate and koto option parts
will try to get more done on it again tonight
dj898
« Reply #11 on: March 18, 2011, 03:47:31 PM »
for the head mod.
the easier way would be this...
pic
after fixing the seam line and painting you can simply click into each other.
also I found lengthening 2mm does make the difference - I had tinkered with this exact kit when I was building Ako Hobby Spartan conversion although ended up using just skirt and bits and pieces off major parts and grafted onto type-c parts.
« Last Edit: March 18, 2011, 03:49:58 PM by dj898 »
« Reply #12 on: March 19, 2011, 08:31:22 AM »
Forearm mod looks nice. This is getting exciting now!
« Reply #13 on: March 20, 2011, 09:04:04 PM »
Cheers dude
Both arms finished now, need to do something to the upper torso and then can start on the legs
Infinity
« Reply #14 on: March 20, 2011, 10:01:36 PM »
Look great dude. Really like the work on the waist unit. Keep it up
Pages: [1] 2 3 4
